Empowering The Innovators:
Making IoT Your Own
RAK Spring Event 2022
- An interface with all the tools you need to create, compile, and debug projects for modular IoT platforms.
- All RAK hardware functionality available as API calls.
Product categories
RAK3172-SiP
WisDuo SiP
- Low-power LoRa® transceiver SiP (System in Package) chip based on the STM32WLE5 Wireless SoC.
- Compared to the original RAK3172, it has more IO pins, integrated TCXO, and comes in a smaller size.
- Supports LoRa P2P and complies with Class A, B, & C of LoRaWAN® 1.0.3 specifications.
RAK4630
WisDuo Stamp Module
- Low-power stamp module that supports both LoRa/LoRaWAN® communication and BLE 5.0.
- Can be deployed as an IoT device without needing an external host MCU.
- Can also integrate external sensors directly by using widely available open-source libraries for sensors and IO interfaces.
WisDuo RAK3272-SiP
WisDuo Breakout Board
- An evaluation board for the new RAK3172-SiP System-in-a-Package module.
- Can be used to evaluate the RAK3172-SiP module with access to all pins of the SiP module.
RAK12001
Fingerprint Sensor Module
- Supports both fingerprint enrollment and fingerprint matching.
- Creates a biometric template of the fingerprint and stores it in internal memory.
RAK12021
RGB Sensor Module
- Detects the color of a surface by using its red, green, blue, and white light-sensing capabilities.
- Proximity detection feature that uses an external IR LED, which can be used as a trigger mechanism to indicate when to start detection.
RAK12025
Gyroscope Sensor Module
- A low-power angular rate sensor module based on MEMS technology that can measure rotation speed in 3 axes.
- Has a 16-bit high resolution and its range of angular velocity can be as high as 2000 dps (degrees per second).
RAK12028/RAK12031
Through Beam Fork Sensor Module
- An optical fork-shaped sensor composed of two small PCB modules.
- The Through Beam Fork Sensor can be deployed to measure motor rotation speed by using an external code disc that spins proportionally with the motor rotation.
RAK12029
Inductive Sensor Module
- Multi-channel inductance measurement sensor that detects the proximity of metal objects.
- This sensor uses a 28-bit inductance-to-digital-converter (LDC) chip that expresses measured inductance using a digital format.
RAK13009
QWIIC Interface Module
- Adapter board that makes WisBlock compatible with Sparkfun Qwiic modules and Adafruit STEMMA QT connectors.
RAK13800
Ethernet Interface Module
- Adds TCP/IP support to the WisBlock ecosystem.
- Data transfer speeds up to 100BaseT.
RAK14007/RAK14013
Joystick Interface Module
- Joystick interface module composed of two PCB modules.
- One analog joystick and four push buttons that can be programmed by the user.
RAK14008
Gesture Sensor Module
- Enables you to control your IoT project simply by waving your hands in front of the sensor.
- Can detect nine human hand gestures including waving your hand upward, downward, going to the left or right, clockwise, counter clockwise, towards or away the sensor.
RAK14012
RGB LED Matrix Module
- Drives an external RGB LED matrix with up to a 16x16 array size.
- Each independent RGB LED in the matrix can be controlled by the module.
- Can be used to build visual panels to show information, warning signs, or other notifications.
RAK19001
Dual IO Base Board Module
- Featuring the highest number of usable module slots of anything in the WisBlock line.
- All GPIOs of this board are exposed with PCB header holes.
RAK19007
Base Board 2nd Gen Module
- Replaced the microUSB with a USB Type C Connector.
- New voltage regulator and a reconfiguration of sensor slot D in the PCB layout.
Battery Plus
- Updated battery unit for WisGate Edge Pro Gateways.
- Solar charging option and status-monitoring systems.
WisToolBox
- Application for configuring RAK IoT firmware.
- Available on desktop and mobile.
WisDM
- Cloud-based device management platform.
- New features including network connection management, MultiWAN monitoring, notification management, and miscellaneous improvements to fleet management.
WisGateOS 2.0
- Latest firmware for RAKwireless IoT gateway devices based on OpenWRT kernel.
- Security enhancements, LBT and spectral scan, LoRaWAN® 1.0.4 support, and support for adding extensions
RUI3
- Learn once, code once. IoT development can be complex and overwhelming.
- Simplify the process by using an interface with all the tools you need to create, compile, and debug projects for modular IoT platforms.
- With hardware functions available as API calls, RUI allows you to build a real-time control system with different baseline functionalities. Develop your IoT devices the way you want them with RUI.
