Assessment of Indoor Air Quality in Buildings
Transform your building's environment with our innovative air quality monitoring sensors
Building A is a modern commercial property located in the heart of the city. It is home to numerous businesses with hundreds of occupants, including office workers, janitorial staff, and visitors. As a multi-purpose property encompassing office spaces, restrooms, and parking lots, Building A is committed to providing a healthy and comfortable environment for all its occupants.
However, Building A faces a significant challenge: maintaining optimal indoor air quality (IAQ) across its various spaces.
The building management faces fluctuating occupancy levels, diverse air pollutant sources, restroom odors, and vehicle emissions in the parking lot. Moreover, they aspire to comply with the WELL v2.2 standard, which requires strict monitoring and control of multiple IAQ parameters.
To address these challenges, Building A is seeking a comprehensive, innovative, and data-driven solution. This solution should not only address the unique needs of each space but also align with their broader goal of creating a sustainable, health-focused built environment.
Problem
Building A experiences a lot of indoor air quality issues due to its diverse use and high occupancy. These issues include:
  • Elevated CO2 levels and volatile organic compounds (VOCs) in office spaces
  • Unpleasant odors and harmful gases in toilets
  • Carbon monoxide (CO) and nitrogen dioxide (NO2) emissions in the parking lot.
In addition to these, they face the challenge of adhering to the stringent WELL v2.2 standard, requiring continuous IAQ monitoring and real-time data availability.
Use Case
To tackle these issues, Building A adopted the following products:
  • Milesight Air Quality Monitoring Sensor: A compact indoor ambiance monitoring sensor equipped with features such as temperature, humidity, PIR, Light, TVOC, Barometric Pressure, Carbon Dioxide (CO2), and Particulate Matter (PM2.5 & PM10) measurements. This product is designed for office spaces, providing real-time data via a 4.2-inch E-ink screen.
  • Milesight Bathroom Odor Detector: A dedicated IAQ sensor for restrooms that detects ammonia and hydrogen sulfide gases with great accuracy. It is designed for easy installation and maintenance, with up to three years of battery life.
  • SENSO8 Car Park IAQ Sensor LRS10701-MN00: A comprehensive Indoor Air Quality IoT sensor. It monitors Carbon Monoxide (CO), Nitrogen Dioxide (NO2), and Ambient Temperature & Humidity, providing real-time data for effective ventilation system adjustments in car parking lots.
After implementing these sensors, Building A was able to effectively monitor and control its indoor air quality.
Use Case image 1
The sensors provided real-time data, allowing the building management team to take timely actions whenever the air quality deviated from acceptable levels.
Benefits
Use Case image
Enhanced Health and Well-being: Continuous air quality monitoring ensures a healthier environment for occupants, reducing respiratory risks and improving overall well-being.
Use Case image
Energy Efficiency: Real-time sensor data allows for optimized ventilation and HVAC systems, minimizing energy consumption and reducing environmental impact.
Use Case image
Maintenance Optimization: Early detection of air quality issues enables timely maintenance and corrective actions, ensuring a safe and pleasant environment.
Use Case image
Compliance and Reporting: Compliance with regulatory requirements is facilitated, with sensor data available for reporting and demonstrating adherence to standards
Use Case image
Data-Driven Decision Making: Collected data empowers facility managers to analyze trends, identify patterns, and make informed decisions to optimize air quality management strategies.
Success Factors
To effectively convince establishments to adopt the air quality monitoring solution, several factors should be emphasized:
Use Case image
Education on IAQ Parameters: End users should be educated on the importance of measuring different gases and pollutants in various scenarios. For instance, CO2 levels might be a concern in office spaces due to occupancy, while volatile organic compounds (VOCs) might be more relevant in toilets.
Use Case image
Relevant Certifications: Having certifications like WELL or other recognized indoor environmental quality standards can lend credibility to the solution and encourage adoption, especially in premium buildings.
What's next?
We can connect you with the solution provider.
Depending on the challenges you face, we can also use the RAK product ecosystem to quickly build a solution with minimal capital investment tailored to your needs. Our goal is to lower the barrier to adopting IoT solutions and help you solve your business problems.
Looking for something else? Browse other use cases or submit your business problem to the Real IoT Marketplace. We’ll do our best to create a solution that fits your needs.
Are you a distributor and interested in marketing this use case? Join the RAK Solution Partner Program and start distributing this use case to your customers.
Are you a solution creator or device manufacturer? If you have solutions or products that you believe are suitable for our customers, submit a use case to be featured in the Real IoT Marketplace. Once approved, they will be published on the platform.
Solution Kit
Experience the convenience and adaptability of the Real IoT Kit solution kit, featuring immediate plug-and-play functionality and the flexibility to meet your unique needs.
Real IoT Kit Mobile
Real IoT Kit
But we don't stop at selling you a solution. With our deep networking knowledge and range of products, we can also help you deploy and scale your IoT solution when you need it.
Easy 3-Step LoRaWAN Solution
Easily build and manage IoT projects with Datacake's low-code platform. We handle the integration, so you can start using it right away. Give your customers the power to build custom solutions and a fully-branded IoT experience.
Hardware Used
Use Case image
Milesight Air Quality Monitoring Sensor (NB308)
Use Case image
Milesight Bathroom Odor Detector (NI301)
Use Case image
Network Options
Cloud
Cloud
Local
Local
Helium
Helium
IoT solutions kits have pre-provisioned gateways and devices onboarded on TTI LNS. However, you still have the option to configure your gateways and devices to work with other LNS like Helium public network or even on a private network via locally installed LNS like Chirpstack. This flexibility is important and depends on your IoT business needs.
Does this use case help solve a problem for you or someone you know?
If you would like to know more, please fill in the form below with your details, and we will introduce you to the solution provider via email.
By continuing, I agree to our Privacy Notice.
I consent to receive marketing emails from RAKwireless regarding its and its affiliates’ products and services.
Uploaded on 05/11/2023
Tags
RAK Selected
